www.mito-forum.de • Thema anzeigen - Lima (lichtmachine) ducati nrg
Beitragvon wertyu-2007 » Samstag 18. August 2012, 13:15
these were fitted to some late model (05/2006) mito evos .
i need to find one ( used ) , thanks .
ducati nrg
the fywheels measures aprox 105mm across which is a smaller than others .
this version also weighs less .
its does have ducati e. stamped on it .
danke jemand
cagiva mito 125 with renthal sprockets,did chain,avon tyres,flat top piston(wossner forged), 200h head 0.8mm squish,raised port timing/port worked 66650e cylinder,tkf con rod,skf bearings ,sp airbox ,arrow exhaust ,VForce2 reed,tm35 mikuni kit
wertyu-2007
